Discussion topic: Sky box
This message was authored by: John538
Sky box
Why is the fourth light 'voice' not working?
Re: Sky box
@John538
As customers here we can't say why that is as this is something you will need to investigate.
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
This message was authored by: peter-marlow+1966
Re: Sky box
Is your  phone connected to the router  ?
P c marlow
Re: Sky box
@John538 Are you on a FF service with sky or digital service with voice delivered via the router, if not then the fourth voice light will remain unlit also can mean that your voice service is faulty if it is delivered via the back off the sky hub.
Re: Sky box
If you  go on YouTube  and sreach sky search sky help there are videos on there on settings  up your hub this may help you
P c marlow
