Discussion topic: Sky booster issues
This message was authored by: Lee97
Sky booster issues
Hey, I have added a sky booster skyse210 to my current WiFi, I have all the correct green connection leads but this doesn't seem to booster signal, I can see the booster as a separate WiFi with full signal? Do I need to connect to this separately?
Re: Sky booster issues
@Lee97 Number one, it should have the exact same name as the sky router that you have, there is something wrong with the way that it is setup, what sky router do you have with the SE210?
