08 Jun 2023 03:14 PM
Hi,
I rebooted all of my Sky equipment today - Q box, router, several miniboxes and a booster.
On the booster, all 3 green lights were on before I started, but now the "connected" light stays stubbornly off even through multiple reboots.
I have done this procedure before quite a few times as I usually try to reboot everything about once a month with no issues.
Any ideas or links to help troubleshoot this?
08 Jun 2023 03:26 PM
Posted by a Superuser, not a Sky employee. Find out moreHave you tried just reconnecting it using the WPS buttons?
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
08 Jun 2023 03:36 PM
I had never had the issue before and I thought it would be more complicated than that because I understood from the engineer that this booster boosts the TV signal as well as the broadband.
Anyway I just tried this and it worked so thank you.
