Discussion topic: Sky boardband issues connecting smart clock
This message was authored by Lukeandannesky This message was authored by: Lukeandannesky
Hi, I've just had sky board band set up and I've had no issues connecting to it with phones, TV, nest, tablets etc apart from my lenovo smart clock. It's the only device I can't connect to my new WiFi network. I've gone into the router settings and split the 2.4g and 5 g and made 2 networks and neither works. Has anyone got any ideas?
Re: Sky boardband issues connecting smart clock
@Lukeandannesky
All i can think is make sure the device you are using to set up the smart clock is also on the same 2.4ghz wifi band
