Discussion topic: Sky WiFi
This message was authored by: Maver
Sky WiFi
My wifi has been fine all week until today when it keeps going down then back up. I currently have no mobile data so this is a big issue I've tried all troubleshooting (resetting, unplugging and ensuring it's central and free of clutter).
Re: Sky WiFi
@Maver
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
