Discussion topic: Sky Stream/internet
This message was authored by: paul101
Message posted on 04 Jan 2026 07:03 PM
Sky Stream/internet
Got pushed into a sky stream. Alao upgraded to 150 broadband. TV is becoming unwatchable every evening with less then 10mbps tonight 1.5
Find out more
Message posted on 05 Jan 2026 07:40 AM
Re: Sky Stream/internet
@paul101 improving speed to your hub wont necessarily improve the WiFi dignal reaching the puck. Ideally you would use an Ethernet cable but the alternative is to improve the WiFi signal. First check that both the hub are out in the open not hidden behind tge TV or on the floor. Beyond that you nedd to consider either paying for Sky's WiFi Max bundle which can provide WiFi extenders or buying your own home WiFi equipment.
When connected properly Sky Stream is as stable as satellite services.
