Discussion topic: Sky SR203 Firmware
This message was authored by: Killersjp
Sky SR203 Firmware
Hi. Just rejoined Sky Broadband and been given a SR203. The Firmware on the router is 7.02.0501.R. When checking on th sjy website it says the latest version is 7.03.0400.R. I have had the router about a week. Should it of updated to the latest version by now. I have been reading the fourum and many replies saying to wait and it will update overnight. I did follow one bit of advice to reset the router which apparently makes it check for a update but still nothing. Is there a timescale of how long until it updates. Many thnaks for reading.
Re: Sky SR203 Firmware
@Killersjp Sky control the firmware version on Sky hubs and there is no way for customers to force an update. It is not unusual for the whole fleet of hubs to take weeks to be updated.  Given there are several million of each type it makes sense to stagger the releases.
Sky very rarely even tell anyone what is in each release the times I have known them to say anything is where a specific issue is being addressed which isnt the current position AFAIK.
Avatar for Killersjp
Thanks for that. Its working fine will just wait I guess. Have a great day
This message was authored by: TomThumb5ive
Sky dev's do have a tendency to inadvertently introduce as many bugs as they fix,
So sometimes being on a later batch of updates, works to your advantage👍
Tom...
Sky want us to believe in better
BELIEVE =accept that (something) is true, especially without proof.
BETTER = of a higher standard, or more suitable, pleasing, or effective than other things or people:
Sky Q & 2 mini’s
SR203 router. > Replaced with ASUS XT9’s with a TP-Link TD-W9970 modem
Sky superfast 80/20 :sort of, 63-75/15. Devolo 1200 wifi > Replaced with cat 6
Sony KDAF8 65 oled.
