Discussion topic: Sky Q box cannot connect to router
Message posted on 24 Oct 2024 11:24 PM
Our Broadband signal appears to be down, but the WiFi test online shows no issues. We cannot use the Mini box for multi room as the main Sky Q box says;
⚠️ There is a problem connecting to your broadband router. If you want to connect to a different router, select Reset.
I've followed the help guidance and have reset all devices now multiple times, without any success, it's becoming a joke how bad the connection has been recently.
Message posted on 25 Oct 2024 07:59 AM
Re: Sky Q box cannot connect to router
@SightlessLaffey What colour is your Sky hub? If it is the latest white type your Sky Q mini cannot connect to it by WiFi insteead you link the mini to the main Q box using wps. Press the wps button on the mini so the led starts flashing do the same on the Sky Q box and if close enough the two should connect.
