Discussion topic: Sky Q Mini
This message was authored by: Dixon+1234
Sky Q Mini
Every single day, my Sky Q Mini is discontinued from my Sky WFI. I have to go through the recommended settings, reset router, WPS ect. Do I require I new box?
Re: Sky Q Mini
@Dixon+1234 unlikely you need a new Q mini far more likely is that is a bit too far from wherever it connects to which could becanother Q box or a. Black Sky hub if you have one. The Q minis should not be networked by WiFi to a white Sky hub. Talk to Sky about supplying a boo ster.
Avatar for Dixon+1234
Re: Sky Q Mini
Thanks and I'm meant to have a Pod in the post from Sky but no sign of it and not in my orders section.
I will call again but frustrated how difficult it is actually speak to someone at Sky.
