24 Mar 2023 02:10 PM
My Sky Q Broadband is not the best, but the main issue is that I seem to have max'd out my number of devices connected at one time. I have about 40 devices trying to connect, looks to be limiting around the 32-35 mark. What can I do? I also have intermittent wifi connectivity here and can only have Sky Superfast available in my road. I would consider swapping out the Sky Q Hub (router) for something else if anyone has any suggestions, but mindful my miniboxes could be impacted if i start changing things away from the default sky q setup.
30 Mar 2023 10:58 AM
Posted by a Superuser, not a Sky employee. Find out moreAs you've found, the Sky box is not that powerful and begins to struggle past 30-40 devices. Ideally you'll want to replace the Sky hub completely. IMO the best options are the Asus AC/AX lineup
