Discussion topic: Sky PRO connection issues
This message was authored by: Forest074
Message posted on 01 Jun 2026 11:27 PM
I am having issues connecting to my SKy Pro better strength service. I use same password but doesn't connect. It worked 3 days ago but now can't connect to it on Xbox series S or Sky
Find out more
Message posted on 02 Jun 2026 07:11 AM
Re: Sky PRO connection issues
@Forest074 not dure what you mean bt Sky Pro. Sky's domestic service provides different routers oneof which iscthe white Sky Max hub which comes as part of the WiFi Max add-on is that what you mean?. The separate Sky Business service supplies different hubs are yiu buying that?
