Discussion topic: Sky Mini Box in Outbuilding
Message posted on 15 Feb 2024 09:08 PM
Hi
we have recently converted a garage(not connected to house) and we have arranged our sky WiFi to be connected to the building which now works well.
I've hit a problem with using the sky mini box. Because the sky q box is in the house very far away, the mini isn't connecting.
is there something I can do to get the mini box to work?
thanks
Message posted on 15 Feb 2024 10:14 PM
Re: Sky Mini Box in Outbuilding
How was that achieved? It may be possible to use the same link for the Mini box.
Message posted on 15 Feb 2024 10:22 PM
Thanks for the reply.
it's a cable run from my sky wifi router to one in my outbuilding. It was a company that I got in so I'm not sure the name of the booster. It's attached to my ceiling if that helps
Message posted on 16 Feb 2024 07:21 AM
@Ladeside123 thst wifi access point will be connected to the hub by an ethernet cable the same cable can be used to network the Q mini by adding a simple unmanaged ethernet switch. You then connect the incoming feed from the house to the switch and run an ethernet lead to the ceiling access point and a second one to the Q box. You may have to ask the company to come back and do that but note buying the leads and the switch should cost under £30.
