1
This discussion topic has been answered Discussion topic: Sky Max router admin GUI (browser)
This message was authored by: Avayaguy
Hi,
I have changed my Sky Max SSID and password to reflect my previous Sky Hub 4.2. - all is working fine
However, I want do some advanced config (remove a couple of IP Addresses from the DHCP Pool etc).
2 questions:
is the web gui still functional?
is my usrname 'Admin' and password some as my new WiFi Password or that on the lable on the Sky Max Hub?
Avatar for Avayaguy
This message was authored by: Avayaguy Answer
Re: Sky Max router admin GUI (browser)
if I had used the right password in the first instance I wouldn't have posted this...
......I'll get my coat
(issue closed)
Avatar for Avayaguy
(issue closed)
