Discussion topic: Sky Max Wireless Pods Set Up Issues
This message was authored by: Steve_David
I received an additional Sky Max Wireless Pod, which i simply plugged in hoping it would connect automatically.
It did not  and just kept flashing across white dot.
I already had x1 pod received last year, and this was connected ok, no issues.
I then proceeded to reset my WiFi, thinking this would resolve the issue.
However  the wifi is back on and not BOTH my Pods do not connect and are constantly flashing the white dot on the front.
Interestingly, the blinking stops after a while.  Then, if I go into the Sky app and try to connect the Pods,  the white light on both pods start blinking slowly again, like it is trying to connect but cannot.
Anyone got any ideas how I can fix this?
This message was authored by: Emmaabb
Re: Sky Max Wireless Pods Set Up Issues
Exactly the same issue here, would like to know how to resolve
@Emmaabb & @Steve_David see this page https://www.sky.com/help/articles/sky-wifi-booster-setup-max-pod note the requirment for the new hub to be registered to your account which you can do by adding to the list in the My Sky app.
