Discussion topic: Sky Max Pod Ethernet
This message was authored by: Reedlover
Hi, I have Sky Max with a Sky Max Pod. All is working fine. However, when I plug an Ethernet cable into the pod it doesn't fit securely nor do I here the click I am used to.
Am I missing something (a few marbles possibly  😉 ) or is this just the way it is?
Re: Sky Max Pod Ethernet
@Reedlover The pods have standard RJ45 connecters so any Ethernet cable should connect and click into place. You aren't by any chance trying to use a DSL cable with smaller RJ11 connecters as these wont click in.
Avatar for Reedlover
Thanks for replying.
I'm using the one I used to connect to my previous router.
I'm going to take another look.
