Discussion topic: Sky Max Login
This message was authored by: 84RRYGB
Sky Max Login
Hello, i have tried everything short of calling in for help. I want to access my router but i am unable as my username & password is wrong. I have tried the admin & sky without any luck. I have tried difeerent things but no luck. Can anybody tell me how to reset my router to default it back to admin & sky login please
thank you
Barry
Re: Sky Max Login
@84RRYGB  Most of the settings for that router are done via the Sky app. But if you do need to login to the router it would be the username of "admin" without the quotes and your Wi-Fi password which is printed on the back of the router or on the card that also comes with the router.
Re: Sky Max Login
@84RRYGB
https://www.sky.com/help/articles/change-wifi-max-hub-settings
This message was authored by: AD2466
Re: Sky Max Login
Hi I just ad the same thing so if you havnt reset your login it should be "admin" and you wirless Password.
