Discussion topic: Sky Max Hub
Message posted on 16 Aug 2025 06:51 PM
Sky Max Hub
Sky Max Hub not showing in App and I am unable to add the Booster Pod, which is positioned very close to the Hub.
Seems to be a common issue.
Please can someone support
Message posted on 17 Aug 2025 07:58 AM
Re: Sky Max Hub
@Oakwood442 see here for the help information Sky provide https://www.sky.com/help/articles/set-up-hub-max-hub-do-you-have-internet-calls
Where Sky have provided the hub it should have been added to your account before dispatchto you if they have missed that step you need to call them to get that done which can take 48 hours. The pod has to be linked to the hub to operate so cannot work until the hub is added.
Message posted on 17 Aug 2025 11:52 AM
Re: Sky Max Hub
Rang Sky. Unable to help.
Can this be escalated?
