21 Sep 2023 04:02 PM
Hi, again.
Second question. It turns out I have a sky max hub and the 2.4GHz and 5GHz signals can't be split. I know some devices are logged onto the 2.4 and some the 5 GHz signal. However my security cameras require a dedicated 2.4 signal. Does anyone know of tips and tricks to get them to connect?
21 Sep 2023 04:06 PM
You may be able to temporarily disable 5ghz in order to connect the cameras and the enable it again but this doesn't always work
21 Sep 2023 04:22 PM
I think we'd established that doesn't work with Max.
23 Sep 2023 07:31 AM
I have tried disabling the 5GHz signal. I think my issue is that my phone registers on the 5ghz and doesn't like the 2.4GHz signal. I'm going to try plugging a wifi extender in and logging onto that as it should be a 2.4ghz signal I believe.
