Discussion topic: Sky Max Hub booster options
Message posted on 20 Jan 2026 12:55 PM
Hey,
I moved to Sky broadband at the end of last, previously with Brawband and had a booster at one end of the house. All devices worked well including external security cameras.
I am on the Fulll Gigafast 900 package with a Sky Max Hub.
My external cameras are not receiving a signal from this box and I assumed getting a booster would help fix this! However, after speaking to Sky multiple times, they have said I cannot get a booster wtih this hub and that I need to pay an extra £8 a month for Sky Wifi Max add on service. Which I am obviously reluctant to do as this defeats the point of moving to Sky and making a montly saving. The reply I got form them is below. So my question is, can I get a booster that will actually work? It seems fairly daft if nothing is compatible.
With your current Full Gigafast 900 package, Sky guarantees a minimum WiFi speed of **25Mb/s in every room**.
However, WiFi boosters are only included as part of the **Sky WiFi Max** add-on, which is a separate service.
I understand this is frustrating, especially as your previous provider included boosters. Without WiFi Max, boosters are not provided as standard with your current package.
Message posted on 20 Jan 2026 02:28 PM - last edited: 20 Jan 2026 02:29 PM
Re: Sky Max Hub booster options
Unfortunately that's correct: the Max booster pod is only loaned to WiFi Max subscribers (and any Max pods sourced elsewhere won't work at all)
However you can choose to use non-Sky wireless 'booster' or 'mesh' products as you see fit: they just won't appear in the My Sky app for administration or diagnostics there.
Message posted on 20 Jan 2026 03:38 PM
Hi @RyeRae
Personally I prefer not to be handcuffed to the supplier, let alone pay them more per month for the privelege of loaning boosters!
A mesh network is the best way to go to ensure seamless wi-fi around your home. This can be as cheap or expensive as you wish, since there are many different suppliers out there starting at under £100 to several hundred pounds depending on the speeds/functions that you need. I personally went for Amazon Eero 6's as I got a good deal on a 3 pack a couple of years ago however there are now many that are cheaper/better value - you just need to decide what features you need and do your research before buying. The bonus is that if/when you move from Sky to another provider, you still have the Mesh in place which makes it very easy and painless.
Good luck.
