Discussion topic: Sky Max Hub WiFi keeps dropping
This message was authored by: Luke55
We have recently opened a Sky Max account. We are a family of 5. 2 stream and all online. It's like the WiFi isn't reaching all rooms and we are having connectivity issues.
Please advise.
Re: Sky Max Hub WiFi keeps dropping
@Luke55 it is quite a common issue that the WiFi signal is not strong enough in every room to stream video. Sky can sell you an add-on called Wifi Max which can provide up to 3 extendrs mathed to the white Sky hubs. You get the first by calling them and asking but another 2 can be authorised after a Sky engineer has surveyed your property.
Alternatively you can buy a third party home wifi system and use that after turing off the Sky hub's wifi which can be cheaper in the long run.
