Discussion topic: Sky Max DHCP wrong IP range
Message posted on 19 Apr 2024 07:52 PM
Hi,
My Sky Max router has just started to play up. Some devices are connecting some are not, on lan and wifi.
The devices are connecting to the network but have no internet. All devices are using DHCP but when checking the IP range on the devices not connecting, they are on 192.168.1 range and should be on 192.168.0. If go in manually and change to the correct range they will work.
How can I check in router to see why it is doing this, as I have some devices I can't manually change, and still cant get internet.
Hope someone an help me
Kev
Message posted on 23 Apr 2024 10:09 AM
Re: Sky Max DHCP wrong IP range
It would be highly unlikely for the Sky router to do this. Are you sure you have not added or changed a device on your network that could be acting as a DHCP server and giving out IP addresses on 192.168.1.xxx?
