Discussion topic: Sky Max Booster Flashing
This message was authored by awynne2002 This message was authored by: awynne2002
Hi all,
i have a sky max hub with 2 boosters in my home, 1 booster has been plugged in for a few weeks and works great and doesn't flash, however i have just received a new one and it has been flashing for a good few hours now which i don't think it should be? it seems to have boosted the wifi connection slightly even though it is flashing, however any ethernet cable connection to it is not working at all, just wondering if i need to set something up or let it settle down for a day or 2?
Thank you!
Re: Sky Max Booster Flashing
@awynne2002 try plugging it in near the router so it can update and connect then locate it where its needed but remember it needs a decent connection to the hub or other pod to operate.
awynne2002
@Chrisee
ive tried as you have suggested here, i have had it plugged in for around 30 mins about 8ft away from the main hub (closer than the other one which works perfectly) and it remains flashing like a white/light pink sort of colour, so i'm not sure wether the booster itself maybe temperamental, or it's working but flashing? as i say ethernet ports are a no go, i tried to connect my Playstation via ethernet and it was unable to connect to not finding an IP address.
thanks
@awynne2002 leave it plugged in and if it doesnt link by tomorrow call Sky.
