Discussion topic: Sky Internet not working
Message posted on 31 Aug 2025 03:52 PM
Message posted on 31 Aug 2025 03:55 PM
Re: Sky Internet not working
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
