1
This discussion topic has been answered Discussion topic: Sky Internet keeps cutting out for short periods
This message was authored by: pat.cuff
My Internet connection keeps cutting out for very short periods, normally around 3 to 5 minutes?
Re: Sky Internet keeps cutting out for short periods
@pat.cuff
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
@pat.cuff
