Discussion topic: Sky Hub not working
This message was authored by: bridgen
Sky Hub not working
My sky hub is not working and saying it is not connected i have reset the wifi and tried to reconnect i have turned the hub off at the wall and waited 5min then turned it back on i have reconnected to the wifi box nothing seems to work
Re: Sky Hub not working
Hi @bridgen
What lights are showing on your hub?
Have  you ran the line test on the My Sky app?
I am NOT a Sky Employee
Avatar for bridgen
Hi Mark
The hub is saying no Internet connection yet phones and other hubs still work.
Yeah ive used the test on the app says all devices are working
Avatar for bridgen
Hi James
Light on the hub is white and app says all devices are working
Thats odd. Are all your devices not connecting or just some?
