Discussion topic: Sky Hub is not connected to internet
This message was authored by: ipad1-tommy
Message posted on 15 Jul 2025 11:29 AM
Your service checker says that everything is fine but no devices are connected to Sky Hub and Sky Hub has a yellow internet light so there looks to be a problem with the outside line (sky fibre).
Find out more
Message posted on 15 Jul 2025 11:42 AM
Re: Sky Hub is not connected to internet
@ipad1-tommy How long after the internet light went amber did you run the service checker? If it is less than an hour it will not see the fault. Try again if it has been more than one hour.
