Discussion topic: Sky Hub is Busy
This message was authored by Ribose This message was authored by: Ribose
Sky Hub is Busy
Past 3-4 weeks I've started to get "Sky Hub is Busy" messages when I try to either load the router page or log in. It mainly happens when the internet drops but it never used to. Any cause for concern or just let it be?
Re: Sky Hub is Busy
Hi @Ribose
Please post your router stats
I am NOT a Sky Employee
Ribose
Re: Sky Hub is Busy
Re: Sky Hub is Busy
Hi @Ribose
Your stats do not suggest a line issue as such however we can see that your WAN interface is dropping.
Can you please make sure all cables coming from your telephone socket are in good condition & are all plugged in tightly.
Can you also please run the connection test in the My Sky app/Online account area and see if that shows anything.
If it doesnt we can escalate your post here on the forum so you can chat with a Sky agent and they can look into it further.
Ribose
Re: Sky Hub is Busy
All cables are clean, undamaged and securely connected on all ends.
Test comes back as "looks good."  "Errors on your line?" is orange Yes, but from what it says, this is normal.
Re: Sky Hub is Busy
@Ribose
I've escalated your post to Sky, look out for a message on the forum
This message was authored by Lisa-P1987 This message was authored by: Lisa-P1987
Re: Sky Hub is Busy
Posted by a Sky employee
Thanks for escalating this. We’ve sent @Ribose  an invite to chat.
Lisa - Sky Tech Team Expert
Ribose
Re: Sky Hub is Busy
The chat has disappeared any chance to reopen it?
