Discussion topic: Sky Hub Max not displaying SSID
This message was authored by: Baldygit68
Message posted on 25 Aug 2026 10:31 AM
I cannot connect to my router as it isn't even broadcasting a WiFi signal. There is no SSID to connect to
Find out more
Message posted on 25 Aug 2026 11:08 AM
Re: Sky Hub Max not displaying SSID
@Baldygit68 try rebooting yhevhub and wait until the indicator light shows white. If you cannot see the SSID then contact Sky but note if this is a replacement hub Sky will have set the SSID and password to matchbthe hub being swapped out. You can check the SID and password by going into the My Sky app finding the Hub's settings the product settings section - the password will display if you click theceye icon.
