Discussion topic: Sky Hub Log in Issue
Message posted on 02 Jun 2025 09:43 PM
Hello All.
I am trying to get into my Family's Sky Hub as one of my devices have suddenly stopped connecting to the Internet.
Reddit mentioned that the device works on any Channel below 10 and Sky'a is on 11 to 34.
I have tried using the Hub's Password and Username, used the standard "Sky" Password" and "Admin", nothing works.
Is there any way to try and log in without resorting to reseting the entire router and causing more issues?
I don't know if anyone in my family changed the settings or the ones who set us up.
Many thanks.
Message posted on 02 Jun 2025 10:20 PM
Re: Sky Hub Log in Issue
Depending on what hub you have it could be that the password is your wifi password so is this what you tried ?
Message posted on 02 Jun 2025 11:16 PM
