Discussion topic: Sky Broadband
This message was authored by: wild+cat
Sky Broadband
Had fibre since the summer been down from 8th jan.26 5 days till to day 12th.cant talk to sky just a recorded message.when on copper never had an outage longer the a rew minutes.
Re: Sky Broadband
@wild+cat
If your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them so they can look in to this for you and if you do call Sky nothing when asked any questions by the bot and remain on the line.
