Discussion topic: Sky Broadband
Message posted on 05 Mar 2025 12:56 AM
Sky Broadband
My Sky Broadband cannot connect, I try everything on the show , it is disconnected
Message posted on 05 Mar 2025 01:05 AM
Re: Sky Broadband
Mines playing up too
Message posted on 05 Mar 2025 03:44 AM
Re: Sky Broadband
At the time you've both posted it could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back in the morning use the below link to check to see if there are any problems or outages nearby
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
