Discussion topic: Sky Broadband Hub - Block Device (Ireland)
This message was authored by: PatWilliamsEire
Hi,
I am looking to block an individual device from my Sky Broadband Hub (in Ireland). I cannot seem to find an option to block a single device when I log onto the router. Is there a way to block a single device?
Re: Sky Broadband Hub - Block Device (Ireland)
@PatWilliamsEire short answer is no the standard Sky Broadband hub does not offer mac address filtering. Even if it did that is likely to be ineffective as mac spoofing is very simple. The only way to excludeca device is to change the WIFI password.
Avatar for PatWilliamsEire
Hi Chrisee,
Thank you very much for that reply. Next question, is the Sky Max Hub available to Republic of Ireland customers or have they kept that back just for their UK customers?
