Discussion topic: Sky 900 Mbps Wi-Fi – Intermittent Connection Drops and Wi-Fi Calling Issues
This message was authored by: Whyfive
Hi, has anyone experienced similar issues with Sky 900 Mbps Wi-Fi?
I have several smartphones and two tablets connected to Wi-Fi. Initially, the connection was not great, and I frequently had to disconnect and reconnect to Wi-Fi manually. I therefore upgraded to WiFi Max, and I now have three extender pods to improve the Wi-Fi coverage throughout my house.
However, the strange thing is that my devices, particularly my smartphone, still struggle with the Wi-Fi connection. More specifically, my phone will show that it is connected to Wi-Fi, but there is actually no internet connection. I cannot open webpages or use apps such as YouTube or Netflix. I have to turn Wi-Fi off on my phone and then turn it back on to restore the connection.
This does not seem right. To identify whether the extender pods were causing the problem, I unplugged all three pods and connected my devices directly to the Sky router. However, over the past few weeks, the same issue has continued even without the extender pods.
The problem occurs intermittently. For example, I might leave my phone locked for 10–20 minutes. When I unlock it, the phone still shows that it is connected to Wi-Fi, but the internet connection has actually stopped working. Again, switching Wi-Fi off and back on immediately restores the connection.
I initially suspected that this might be caused by the settings on my smartphone. However, I have not changed any relevant settings, and I never experienced this problem with my previous ISP. More importantly, several other smartphones in the house experience exactly the same issue, so it is very unlikely to be a problem with one particular device.
I have also noticed another potentially related issue with Wi-Fi Calling. Occasionally, my mobile phone does not ring when somebody calls me. Instead, I later receive a text message notifying me that I have missed a call. My partner has also told me that sometimes they cannot get through to my phone.
I eventually discovered that disabling Wi-Fi Calling appears to resolve this problem. However, this is obviously not an acceptable solution. I have been using Wi-Fi Calling for at least five or six years without any problems with my previous ISP, so there appears to be something wrong with the Sky Wi-Fi connection.
When I log in to the Sky router, there are only limited settings available for me to change, as many functions appear to be automatically managed.
My suspicion is that either there is some type of power-saving or sleep function in the background that is intermittently disconnecting devices; or there is some form of periodic connection/service check that is unintentionally interrupting the network connection. (trust me on this, I learned my lesson from Virgin Media.)
I have also tested the connection using an Ethernet cable, and I have occasionally noticed brief interruptions there as well. For example, a streaming video will suddenly stop buffering or playing and then resume after a few seconds. This makes me think that the problem may not be limited to Wi-Fi itself.
Has anyone experienced the same problem with Sky Broadband/WiFi Max, particularly where devices remain shown as  connected but temporarily lose internet access?
Could Sky please advise what might be causing this and provide a suitable solution? I do not think repeatedly turning Wi-Fi off and back on, or disabling Wi-Fi Calling, should be necessary to maintain a reliable connection. Thank you.
Re: Sky 900 Mbps Wi-Fi – Intermittent Connection Drops and Wi-Fi Calling Issues
@Whyfive you are not talking to Sky by posting in the forum so if you want their help,you will have to call them. There literally millions of the Sky Max hubs in use and most users do not suffer the issues you report.  This should not be impacted by the use of the Sky WiFi Max pods assuming they were supplied by Sky. There have been reports of issues where the pods were obtained through other sources and you are not listed as a Sky WiFi Max customer.
WiFi calling is controlled by your mobile provider and there are regular reports of issues with WiFi calling with some of the virtual mobile networks Sky's own mobile service occasionally has blips. Thesecsre related tomthe mobile network not the broadband service.
There are no power saving settings on the hub's but if a device is not connected for a period there can be delays in obtaing a fresh lease of an IP address. It is worth trying to reserve an IP address which can speed that process up. Go into the hub's web interface at 192.168.0.1 log in with the username admin and the default WiFi password. Then navigate to the connected devices list open the device and hit the reserve ip radio button.
This message was authored by: Emon2
I am experiencing the same issue with Wi-Fi Calling on my iPhone while connected to Sky Broadband, and what is particularly concerning is that, despite the amount of time that has passed and the large number of reports in this discussion, the problem still appears to exist today.
Wi-Fi Calling can randomly stop working even when the Wi-Fi connection itself is stable and fast. Incoming calls may fail to arrive over Wi-Fi, and ongoing calls can unexpectedly lose Wi-Fi Calling and switch to the mobile network.
Considering how long this issue has been reported and the number of users experiencing similar problems, I believe Sky should seriously investigate whether there is an underlying problem with the configuration or management of its routers and network infrastructure.
Similar reports also seem to come from Sky customers in different countries, using different devices and mobile operators. This makes it increasingly difficult to consider the issue as being limited to individual phones, Wi-Fi signal strength, or isolated home networks.
The fact that this problem is still being reported today, despite the time that has passed since the earliest reports in this discussion, suggests that the underlying issue may never have been properly identified or resolved. Hopefully, Sky Support will now start taking these reports more seriously and investigate whether its router or network configurations could be affecting the persistent connections and keep-alive traffic required for Wi-Fi Calling.
:::writing
