Discussion topic: Siro no led
This message was authored by SlanAH This message was authored by: SlanAH
Siro no led
Hey. My Siro box has no power. All the leds are off. Checked the power cable and all is secure. Pushed the power button on and off on the box. Still nothing.
All other devices have power. O don't think resetting it with a paper clip will work if it's doesn't have any power.
Has anyone else had this issue?
Re: Siro no led
@SlanAH
Aside from checking there's definitely power to the socket (using a lamp or similar) there's nothing you can do other than logging a fault with Sky and arranging for despatch or delivery of a new ONT.
