Discussion topic: Siro down in meath
This message was authored by: Ted-_
Siro down in meath
Siro causing Internet issues?
Re: Siro down in meath
@Ted-_
What is a siro ?
@caesarome
It's one of the wholesale FTTP networks in RoI: technically it's Vodafone Ireland running optical fibre alongside power cables belonging to the state-owned Electricity Supply Board.
https://siro.ie/about-us/
Avatar for Ted-_
It runs the fibre coming into the house
Went  into  all sorts of troubleshooting with a tech  on wassap. Then found  out other  people in estate having  same issue..
And the issue  was with siro. That the tech did not know.
Everthibg looks fine. Lights etc but no Internet.  Been out since last  night
No fix time.
Very little info  from  sky Ireland.
Its random  aswell  effects some and not others
This message was authored by: CarlSky194
Yes, same issue here, on tech support on whatsapp for ages and nothing, network engineer arranged, I called again and they found that it's an edge case issue with siro, even siro says no outage.
It's really annoying trying to figure this one out, and no news if it's resolved or not.
This message was authored by: DaveF75
No internet since yesterday
I have ni high speed Internet connection since yesterday checked this morning before I went to work and still down , Trim Co.Meath Ireland
Re: No internet since yesterday
@DaveF75   First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
