Discussion topic: Significant drop in speed
Message posted on 12 Feb 2026 01:35 PM
Over the last week my broadband speed has dropped from 24 down to just 2. This is causing a major issue for me as I work from home. I have tried checking all the connections from my wall socket to my router and tried resetting my router multiple times. Im not sure what else I can try.
Message posted on 12 Feb 2026 01:45 PM
Re: Significant drop in speed
@ScottishRay82 You can run the diagnostic check as linked below, especially if you have a bad line!
Try running the line test here to see if any faults are found:
