Discussion topic: Signal
This message was authored by: Julieanne43
Signal
My TV keeps disconnecting from the wifi,I have 1 booster and I prioritise my TV,but this has made no difference,I have the fibre fastest speed broadband,I restart the router and disconnect anything that's not being used,sometimes only my phone and the TV is conand still the TV os buffering or disconnecting
Re: Signal
@Julieanne43
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
