Discussion topic: Signal
This message was authored by: Kellieads1
Signal
Hi Our WiFi signal around the house has been really bad yhe last couple of weeks. Can't watch stuff on You Tube and games are lagging out.
Re: Signal
@Kellieads1
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Re: Signal
@Kellieads1 Have you just tried resetting your sky hub by powering off / on and see what happens!
