Discussion topic: Signal
Message posted on 13 Jan 2026 12:12 AM
Signal
Our signal up stairs is weak, how can this problem be solved?
Message posted on 13 Jan 2026 06:24 AM
Re: Signal
@IloveRusty4ever Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
