Discussion topic: Signal keeps dropping out.
Message posted on 28 Mar 2025 11:14 AM
Message posted on 28 Mar 2025 11:29 AM
Re: Signal keeps dropping out.
@SShields65
Message posted on 28 Mar 2025 12:22 PM
Thanks, but I have done all the checks and called the number given to me by the email reply to my report of an issue.
Message posted on 28 Mar 2025 12:25 PM
I'm not sure from that if you spoke to Sky or not so…
To call Sky dial 150 (free) from your Sky Talk landline or a Sky mobile. Alternatively use this link…
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The posting of full phone numbers isn’t permitted on the forum.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
