Discussion topic: Signal drops alot
This message was authored by: Dferrar
Signal drops alot
Signal drops alot
Re: Signal drops alot
@Dferrar if you would like help from forum members you will have to post some details such as is itvthe hub losing connection to the line (the leds on the hub will show if that is happening) or it is devices losingbtheir wifi connection as the so,utions are quite different.
