Discussion topic: Signal Booster
This message was authored by: Mikee80
Signal Booster
I have recently moved over from BT to Sky and am having problems getting wifi in certain parts of the house - front room tv and ring doorbell. The router is upstairs. With BT we were provided signal boosters. I see that Sky has them but I cannot find out how to get one and have been going round and round in circles. Any help appreciated, thanks!
Re: Signal Booster
@Mikee80
If you already have Wi-Fi Max', or now choose to purchase it as an add-on (currently about £6 a month), Sky will loan you up to 3 booster pods. Call Sky to arrange the first one which is for self install. Just dial 150 free from your Sky Talk landline.
To add a second or third pod it requires an engineer visit to check your set up.
https://www.sky.com/broadband/wifi-max
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Mikee80
Re: Signal Booster
Thanks! We have the Full Fibre Gigafast, with Sky Max Hub. We dont have a Sky Talk Landline however. Do you know the number I can call, as again I am going round in circles trying to find the info!
Thanks so much for your help 🙂
Re: Signal Booster
@Mikee80
You actually do have a Sky Talk landline as it's bundled with your broadband package but you have chosen not to connect an actual handset which is fine and entirely your choice.
In the future you can plug in a cheap handset when you need to call Sky (dialling 150 free) if the Sky Talk side of things are working..
These are the current methods available for contacting Sky. Some methods may be more appropriate than others….
🟢📞 Call Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you’re a Sky Broadband customer. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
Note: If your Sky services are restricted due to a missed payment, calling will only result in a request to pay.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps route your call into the queue for an agent.
🟢online help via this link
🟢Sky Assistant 💬 should also be available via
🟢Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
♦️Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of any link is showing the correct flag and change if required. The Sky Ireland phone lines have different operating hours to the UK and are closed over a weekend.
Avatar for Mikee80
Re: Signal Booster
All of the online chat services you have linked here take me round in circles again.
When I phoned as you suggested, Sky automatically text me taking me back into the perpetual help topic circles!
The signal checker they recomended says our internet is ok, which it is upstairs when sat next to the router - however downstairs the tv is buffering and the ring doorbell isnt working so it is not ok, and falling short of the wifi max guarantee
I just really want to get the signal booster as I was happy with that / it worked with the BT booster
Do Sky have an email I can contact them on so I can explain the problem?
Re: Signal Booster
@Mikee80
Unfortunately for you Sky don't use email for general communication hence it wasn't mentioned earlier.
Avatar for Mikee80
Re: Signal Booster
So I am unable to get a signal booster from Sky, even though I have no wifi in one half of my house?
I have tried every method of contacting Sky and like I said, they are saying my wifi is fine because the connection test speed says its ok
Surely there is a human I can talk to somewhere at Sky?!
