Discussion topic: Showing wifi signal strong but phone.not connecting
This message was authored by: md+aris
Message posted on 10 Sep 2025 01:44 AM
My hub is running as should be i have booster in middle.floor and one on top floor both boosters connected to each other and to hub but i phone shows connected but wifi signal not coming
This message was authored by: nicjayne1985
Message posted on 10 Sep 2025 02:10 AM
Re: Showing wifi signal strong but phone.not connecting
I currently have a flashing green light but all app tests are showing everything is fine 😕
Find out more
Message posted on 10 Sep 2025 07:56 AM
@md+aris & @nicjayne1985 at the time you bothposted it is probably caused by essential overnight maintenance affecting your lines. If that was the cause your connection will be back this morning.
