Discussion topic: Should I received WiFi pods
This message was authored by: Andyg31
Hi can anyone help me I've just had my hub delivered and connected I've had the WiFi add on for all rooms and not had any boosters delivered do they come separately I've now got no WiFi in 4 rooms
This message was authored by: splatto
Re: Should I received WiFi pods
You won't get any automatically, you have to request them. If you need more than one they send an engineer to test for dead spots and find the best locations.
@Andyg31 as @splatto explains, even to get your very 1st one you need to call sky, go through all the hoops and testing then also the same for number's 2/3 but with an Engineer in tow as to why all 3 are needed! Hopefully they don't ask you to wait the 10 day's especially if you have had a previous system and KNOW that additional is required for operation... It's all in the linked info below, so do the read before the call!
getting sky max and how to get the pod's
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
I got my Max hub on a Friday, phoned to enquire about pods on Saturday and received it Tuesday. I only needed one so didn't need an engineer visit.
