cancel
Showing results for
Search instead for
Did you mean:
Shockingly bad WiFi speed
Malvern22
Level 1
Just 2 weeks into sky broadband and it's dropping out consistently and is shockingly slow!! Help
2 REPLIES 2
caesarome
Level 16
Re: Shockingly bad WiFi speed
Message contains a hyperlink
@Malvern22
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Chrisee
Level 16
@Malvern22 check that there isnt an issue with the speed to your hub by running the service checker in the My Sky app if there isnt then the issue is likely to be poor WiFi in your home. If that is the issue Sky sell an add-on which can provide boosters see https://www.sky.com/help/articles/sky-wifi-max
