Discussion topic: Shield settings
This message was authored by: Emmalou82
Shield settings
Im confused by the custom settings in shield. Are you supposed to tick the categories you want to allow or tick them to not allow them?
Re: Shield settings
@Emmalou82
That depends on what you are trying to do so does this help:
https://www.sky.com/help/articles/sky-broadband-shield-using
This message was authored by: Midiless
Re: Shield settings
I too had the same question and found the available documentation/links confusing and/or economical with the truth!
Basically it appears that with the "custom" setting in the resultant category list all items are inactive (including desirable Phishing and Malware) and one has to select using the tick boxes on the left to include items one wishes to block.  I would certainly have expected the Phishing and Malware category to be active by default as in the other age categories!
