Discussion topic: Shield settings problem
Re: Shield settings problem
@fed+up+with+sky66
What number did you ring? Where did you find it? Calls to sky are free for customers on 150 from your landline or
zero three three three seven five nine one zero one eight from any other phone
This message was authored by fed+up+with+sky66 This message was authored by: fed+up+with+sky66
As sky telephone number is harder to find than a needle in a heystack, I googled it and dialled the number that was provided.
This message was authored by Jusna This message was authored by: Jusna
I unable to take off skybroadband sheild setting
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
@Jusna
Why not? Are you getting an error, if so what does it say?
"Sometimes, the only choices you have are bad ones, but you still have to choose"
This message was authored by Karactacus This message was authored by: Karactacus
I want to access adult content it was never a problem with other broadband providers
How do l access shield settings
@KaractacusIf you are the main account holder then log in on my account, go to the broadband & talk tab you will find broadband shield, this can be either set to 18 or switched off which ever works best.
This message was authored by RunningMonkey This message was authored by: RunningMonkey
I have the same issue. When connecting from iPhones and Ipads several apps and websites do not load. If I disable the sky shield or use 4G it all works fine
