24 Oct 2023 01:49 PM
Hello, I am experiencing massive Wi-Fi lag and drops while using my PS5, so much so online play is impossible. I have a sky router connected wirelessly to sky Q box, sky Q mini in the top floor of the house and ps5 connected wirelessly. Connecting via Ethernet isn't easily and would be a lost resort.
Here are the router stats
24 Oct 2023 01:55 PM
That's very good FTTC, so the issue isn't there.
Gaming through a Q Mini hotspot would be very undesirable though.
24 Oct 2023 02:02 PM
Can I just unplug the mini box from the power to test if there's any improvement? Or do I need to wipe it totally from the network?
24 Oct 2023 02:05 PM
Unplugging it would mean you'd know you are connecting to either the main Q box or the Sky Hub.
24 Oct 2023 02:08 PM
Does the main sky box act as a repeater of sorts then?
if so can I connect via Ethernet to my PS5???
24 Oct 2023 02:15 PM
Posted by a Superuser, not a Sky employee. Find out moreAll Sky Q gear acts as a repeater/booster so its quite possible your connection is going from Router > Sky Q box > Sky Q mini box > PS5. Try temporarily unplugging all your Sky Q gear and see what the connection is like .
