Discussion topic: Severe bufffering.
Message posted on 11 Oct 2024 01:53 AM
Severe bufffering.
I am getting a lot of buffering when playing online video programmes. Any help to rectify this would be most welcome.
Message posted on 11 Oct 2024 06:59 AM
Re: Severe bufffering.
@StMaurSKY0217 the most common cause of buffering when streaming video is poor WiFi signal to the device. People often assume thst if they have a fast broadband service to the hub the WiFi will also be fast which simply isnt true as WIFi signals are affected by the layout and type of construction in your home.
Check thst your hub is in the best possible place which is out in the open on a surface above obstructions like radiators. Do thecsame with the devices you are streaming - people often hide the firestick or Sky `stream puck behind a TV which blocks the signal as it contains metal. Beyond that you are into getting extra wifi kit.
