Discussion topic: Setting up the main sky q box as a range extender
Message posted on 23 Dec 2024 10:16 PM
My main sky q box it at the other end of my house and is hard wired to my router. However my iPhone cannot see my home Wi-Fi. Do I have to switch this on, in my q box and if so where is the setting? Thank you 🙂
Message posted on 23 Dec 2024 10:30 PM - last edited: 23 Dec 2024 10:31 PM
Re: Setting up the main sky q box as a range extender
Which router do you have in use?
With a Sky Q Hub or Sky Broadband Hub the hotspot functionality should be automatically enabled.
Message posted on 24 Dec 2024 07:22 AM
@Mark436 to add the WiFibextendercfacility on Q boxes does not work with the white Sky Max hub unforunately.
Message posted on 24 Dec 2024 12:07 PM
I cannot seem to find anything on the sky router to confirm what model it is nor on the Q box. Last night my iphone picked up a signal but it didin't have the full bars and I was sat about 10 feet away from the sky Q box. I'm not convinced it is emitting a wifi signal as surely I should have all the bars on my iphone for signal strength.
